Set > Props (5)
Animation > iMotion (30)
This new animation pack is for your G6 and CC characters. Since there are very few animations that work well with the new characters being created in Character Creator and the standard G6 characters, without a lot of tweaking, I decided to make some new ones for us to use. These animations were designed with CC Characters in mind.
In the construction pack You will get 30 animations. There are several different type of animations for nailing floor boards, steps, standing upright and on a ladder. I have included a hammer, box of nails and a nail prop that can be used with these animations to add to the realism.
Your character will also be able to construct a block wall with the block animations. He can lift blocks and can place them on a partially built wall. I am including a cement block porp to be used with these animations. I also have pre - built walls and cement blocks in my Construction Pack that work well with these animations available in the marketplace or my store, along with 2 dozen other props for building.
Your characters can also use a level for making sure that walls are level both upright and horizontally.
I am including a level for your characters to use in the pack.
I have also included several foreman animations so you can have the boss tell his workers what to do and view blueprints to make sure that everything is being constructed according to plan.
*Some very minor tweaking of the hands may be necessary if you are using characters that are taller or fatter than the original CC characters
iClone > Motion > Combat > Hit & Dodge
