Set > Props (3)
This two story corporate building is a complete modern office complex. It is supplied as 3 parts, that when added to the stage, will line up perfectly to create the full building. It is broken down as follows:
1) Building Shell
2) Lower Floor
3) Upper Floor
Everything is set up as sub-props and the props on the Lower Floor are attached to floor, as well as the props on the Upper Floor, are also attached to Upper. All Walls and Ceiling can be hidden for better camera angles.
All images are rendered in iClone 7. Video is rendered in Unity. There will be some texture variation - see promos.
