Set > Props (1)
Cuppa Joe is a complete "animation ready" set which will load exactly as the promos and ready to animate. Each Wall is a sub-prop and items on the walls are attached to the appropriate wall so when you hide any wall, all items on the wall will hide with it. The Ceiling is also separate for easily hiding. Every prop in the coffee shop is a standalone, with pivots set correctly so you can easily move, delete or save for other projects. Glasses and coffee cups are attached to their appropriate table or shelf. These are easily saved for adding more coffee cups around the shop, depending on your scene.
Additionally the two front doors have a "Perform" menu to "Open Door" or "Open Door, Pause, Close Door".
Not only is this set perfectly charming, it is completely ready for your animated stories.
About Vanishing Point:
"Established in 2004, Vanishing Point designs and creates the most advanced, sophisticated and versatile 3D models for various platforms and applications.
We are a premier content provider for a number of software applications, including Poser Pro, Vue d'Esprit, 3D Studio Max, Lightwave, fbx/ Unity, and iClone."
iClone > Set > Props > Modern Prop
