For iClone only:
  • Actor > Legacy Standard Human (2)
This is a set of Demon / Bat Morph Prop wings which provide morphs for retracting (folding) the wings and for flapping the wings.
Each wing (right and left) is implemented individually allowing each wing to be controlled independently.
The wings are implemented as iAvatars (not iProps) so as to be able to include the Retractable and Flap morphs.
The wings are textures with a semi-transparent texture simulating a membrane like skin. Turning the wings texture less transparent will make the leather texture and skin creases more prominent if a more solid wing appearance is desired. The wing mesh allows for a texture to be used on either side of the wing - if desired.
Contains:
1x Bat Wing Right Morph Prop (iAvatar) with Retractable And Flap Morphs.
1x Bat Wing Left Morph Prop (iAvatar) with Retractable And Flap Morphs.
HOW TO USE:
1. Add each wing to the project. You will find the Wings in the Avatar section (not Prop section) under the Morph Props sub-folder.
2. Position wings are desired.
3. LINK the wings to the desired character to ensure that they move with the character.
4. Click on the wings and use Face Puppet (3DXChange Slot 1) to manipulate the wings.
Move Mouse Down/Up = Retract wings / Expand wings
Move Mouse Left/Right = Flap wings. The direction are reversed for each wing.
