Pre-animated destructible props from the developer of the original destructible props. Animated with Physx. Just dragndrop then press play or remove animation then use the right click menu to trigger animation at desired time. These will not work as fragments with iClone physics.
I N C L U D E D :
1- Cascasde Shatter Floor Prop
1 - Collapse Floor Prop
1 - Seam Shatter Floor Prop
1 - Hole Collapse Floor Prop
1 - Shatter Floor Prop
