Detention Cells - iProject with individual cells. Use the file or save out the cells (1 & 2) to create your own cellblock with the stock room prop dependent on what your computer can handle. Individual cell doors are animated to open and close. iProject comes with back wall image prop with cell image rendered in iClone from cellblock to make the hallway look longer. Must be careful with camera angles to make this work. 3 prepositioned cameras are setup in the project file. Remove or turn off the visibilty of the Back Wall Image to remove. Individual cells have walls created and textured with the ability to turn off the opacity (visibility) of the walls for easier filming thus not being dependent on clipping with the small floorplan of each cell. Cells were made to specific dimensions by request (4X6 cell with 5X3 bed). G3 characters can be resized to 80% to better fit bed if you don't want to have them hang their legs off the end. Front walls of the first two cells in the block have the opacity turned off (down to zero) for filming. Select each of these cells then appropriate wall to turn the opacity to 100% if you want them to be solid walls. iProject Setup Includes: Main Camera Cell 1 Camera and Point Light Cell 2 Camera and Point Light Hallway Spotlighting Atmospheric Lighting (go to atmosphere to turn off) Since the project has atmospheric lighting the lighting will change with the camera angle. Turn off the atmospheric lighting or adjust it if this causes problems with your intended use.
Universal Project
