Animation > iMotion (8)
DC_BackWalkStCycle
DC_GrazeA
DC_GrazeB
DC_IdleA
DC_IdleB
DC_RunStCycle
DC_TrotStCycle
DC_WalkStCycle
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Animals by Arteria3D.
This is the Donkey Colt by Arteria3D.
This Pack contains a Donkey Colt Avatar. The Donkey was ported to iClone by Bigboss. He is presented as non-human .iAvatar that can be fully animated inside iClone.
Furthermore, the Donkey come with his own AML persona and 8 high quality motions; IdleA, Walk, Trot, Run, IdleB, GrazeA, GrazeB and Step Back. The Walk, Trot and Run motions are perfect cycles that can be repeated on the timeline. You can also operate the Donkey in iClone Director Mode !
The Jaw and Ears of the Animal are skinned to separate bones so that you can also animate them using the iClone Motion Layer Editor.
IMPORTANT NOTE: The Motion files for these Animals must reside in the "$iClone Template\Motion\DonkeyColt\" folder for the AML to find its way to the motion files Whereby "$iClone Template" environment variable typically translates to:
C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 4 Template\iClone Template\
Unfortunately, in REALLUSION City, upon download, the installer will put all motions in the iClone Root Motion folder, i.e. "$iClone Template\Motion\”, thereby, once the installation is complete, you need to create a sub-folder and copy the supplied motions into that folder for the AML to work, i.e create a \DonkeyColt\ sub-folder and copy all motions into it. This will then enable you to invoke motions directly from the Avatar Right^Click Pull-Down Menu
Have fun!
Bigboss40@videotron.ca
