Set > Props (16)
This is the Door Package Plus by Cricky.
This package contains 16 different Props including 13 modular Doors, Door Casing, and a Separate Pull Handle.
The Pivot points are preset at the lower left center, but can easily be changed. The doors hardware can be separated/scaled/moved inside 3dXchange.
The hardware can be extracted inside 3dXchange and re-grouped or moved and re-sized.
All parts are currently merged inside the project and may affect the sizing of these components, so consider this when scaling the overall door. Separate the components into appropriate groups in 3dXchange as needed, then send the entire door back to iclone for further editing.
The components, when separated, can be set to "not be affected by the door scale" by choosing these options (Not to scale attachments, just use Move and Rotate) inside iclone; then you would only have to reposition them inside the scene and scale as needed inside iClone.
In other words you have options, and have to decide on your own approach as not all scenes are created equally, and that is the reason why all components were created in the method used.
These doors can be useful for variety inside your projects, and most areas have their own UV defined maps. Try various Materials, and see what you can change.
Method of use:
1) Apply Doors to scene
2) Customize to your liking
3) Save Prop for later use.
These Props were created by Cricky.
Have fun!
iClone > Set > Props > Exterior Prop
