Character > Cloth (3)
Base Content
Double Breasted Coat - based on 1940 Coat by Sckript
Note: To use this pack, you need to own the 1940 Coat by Sckript pack - link on description page.
3 Modern Coat variations for the coat by Sckript. I've created an RGB map so you can use the appearance editor in Character Creator to add your own patterns. Buttons and Stitching are a decal. For a different pattern or material, simply select the coat and launch the appearance editor and make change to desired channel.
This pack is the cloth only - the character, hair, scarf, etc. are not included.
Installs as follows in Character Creator:
Cloth/Full-body/CC_Alley/Double_Breast_Coat
Coat by SCKRIPT - click on image below for link - or check the link on the description.
