For iClone only:
  • Actor > Non-Standard Human (4)
  • Set > Props (4)
  • Animation > iMotion (27)
Bigboss is proud to announce the arrival of a series of absolutely outstanding and stunning fully animated Animals & Creatures by PROTOFACTOR.
This is the DRAGONIDE Fantasy Creature by PROTOFACTOR.
This Pack contains a DRAGONIDE Fantasy Creature for iClone plus 27 high-quality Standard Human Motions that can be used on other iClone standard Characters. The Creature is supplied in 4 different color schemes both as a Non-Standard iClone Avatar and as an iClone Prop with embedded animations.
About PROTOFACTOR Animals & Creatures:
Each PROTOFACTOR Character use high quality texture maps and a very small polygon count providing excellent visual quality for close-up shots. The Prop version of the Character provides additional functionalities such as the capability to use the multi-duplicate iClone feature and the capability to apply key frames to the scaling of bones which may be required by some of the provided custom animations.
Method of use:
1) Simply Apply the Creature Avatar or Prop to your scene
2) Right Click on the Creature to select the appropriate performance
3) You can alternatively Drag&Drop motions on the Avatar version of the Creature
4) Use the iClone "Multi-Duplicate" tool to clone the Prop version of each Creature along a vector or circular path.
5) Edit the applied animations on the timeline to add randomness to each Creature move.
6) Another interesting trick is to attach or link your animated Creatures to a dummy Prop and have the prop follow an iPath during the animation !
Have fun!
Standard HumanUniversal
