  • Material > Props (10)
  • Set > Props (3)
Bigboss is extremely proud to announce the arrival of a series of amazing special iClone Props by Cricky.
This is the Drink Cup Can N Thermos Pack by Cricky.
This Pack contains 3 animated beverage containers (Drink Cup with Straw, Pop Can and Thermos Bottle). The Drink Cup include an animated Straw that falls into Bubbling Cola. The Pop Can has an animated Tab with popping noise and the Thermos Bottle has an animated removable Cap. The Bubbling cola is simulated using an optional physics enabled soft cloth surface.
Note: The Material Files for an additional set of 10 Drink Labels are also provided as a Bonus.
A must have for all Beverage Lovers !!!
IMPORTANT NOTES: The Bubbling Cola dynamics are based on how your Physics parameters are set. Keeping your World Scale Low (1, 2, 3,etc.) and a constraint stability scale of (3) or Greater will give you better results. Also keep the animation for all your Physics props in a Frame-By-Frame viewing status.
Method of use:
1) Apply Props to your scene
2) Set Play Mode to ''By Frame''
3) Press Play...
These Props were created by Cricky.
Have fun!
Bigboss40@videotron.ca
UniversalUniversal
