For iClone only:
  • Actor > CC iCloth (19)
  • Actor > CC iShoe (4)
  • Actor > Legacy Standard Human (4)
Base Content
Egyptian Guards based on Egyptian Guard Old Kingdom by Delerna
4 outfit options for the Egyptian Guard by Delerna. Characters also utilize items from the Medieval Tunic by Delerna. The characters will have watermark if you don't own both the Egyptian Guard & Medieval Tunc by Delerna. Or you can choose not to use the Arm Guards and the leg straps and then you only need the Egyptian Guard Pack.
The characters have collison added based on the default male build. They also have skin opacity under the cloth. If using on another character, export the skin opacity map from the Skin Body channel to apply to other characters. Additionally, you can save the ini file (which sets collisions) by selecting the character, then select "Collision Shape" and export the .ini to import later on a new character. However, every change to character size will likely require you to tweak the collision shapes.
Items will install in your iClone Default Directory as follows:
Characters - Avatar/CC_Alley/Delerna/Egyptian_Guard
iCloth - BodyPart/CC iCloth/CC_Alley/Delerna/Egyptian_Guard
iShoe - BodyPart/CC iShoe/CC_Alley/Delerna/Egyptian_Guard
Click on the links below to purchase the Egyptian Guard and/or Medieval Tunics by Delerna.
CC1 CharacterCC1 Character
