Set > Props (2)
This is the animated Electronic Attitude Direction Indicator (EADI) by Bigboss Big Brother.
This pack includes 2 fully animated EADI Assemblies featuring 2 types of vertical deviation and aircraft symbols. The Props are low polygon count and are fully optimized for real-time response.
Best use in Scenes requiring close-up on Aircraft Instrumentation during flight.
Method of Use:
1) Apply Prop to your scene
2) Press Play
3) Adjust animation speed by stretching or compressing the animation Clip on the Timeline
4) Multi-Duplicate as desired
5) Optionally attach prop to other props to make bigger assembly
8) Save Assembly for future use.
Further customize by modifying the Materials.
This Pack is complementary to all other Mechanical Assembly Packs by Bigboss Big Brother.
Have Fun ! :)
Bigboss40@videotron.ca
iClone > Set > Props > Air Vehicle
iClone > Set > Props > Sci-Fi Prop
