For iClone only:
  • Actor > Non-Standard Human (2)
  • Set > Props (1)
Bigboss is extremely proud to announce the arrival of a series of amazing special iClone Characters and Props by Cricky.
This Pack contains a complete iCar Compatible Fire truck Emergency Vehicle with Light Set.
The lights are Puppet Controllable with the Avatar Controller as separate sets;
Method of use:
1) Simply Apply the Fire truck and all light sets to your scene
2) Link Light Sets to Fire truck
3) Select desired light set
4) Animate light set using Avatar Controller Panel
ADDITIONAL NOTES:
DO NOT Drag the Avatar lights in !!! They are pre-positioned on the the iCar model included with them, and will snap to their intended position if you just double-click the item in your inventory or use the "Add to scene" button.
The same applies for the first use of the iCar, just double click or use the add to scene option.
Once added to the scene, the Avatars are "LINKED" to either the Car Body or to "Spring01"
http://file.reallusion.com/ic/Puppet_Controller.exe
This controller is required to operate the Emergency Light Avatars. Free from ReallusIn
http://forum.reallusion.com/FindPost168336.aspx
These Characters and Props were created by Cricky.
Universal
