  • Set > Props (1)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Morphable Props for iClone called ''EZ Morphs''.
This is the ''EZ Morphs Terrain'' by Bigboss.
This pack include an amazing Terrain Prop you can shape and Animate on the timeline. Dummy Handles are provided as helpers to shape each of the 3 Terrain Layers to perfectly fit your scene. In addition to this, each handle can be animated on the timeline thus providing endless possibilities such as making a volcano eruption, simulating earthquakes or even moving bunnies and ground hogs travelling underground and popping out through an erupting hole in the ground !
Method of Use:
1) Load EZ Morphs Terrain Prop
2) Shape to your liking by selecting and moving the dummy handles
3) Move timeline cursor to the right
4) Move dummy handles to set other key frames
5) Return timeline cursor to frame zero
6) Press Play !
7) You can optionally select the EZ Morph Terrain Prop, right click and Add to Terrain to save as terrain.
WARNING !!!
EZ Morphs Props uses Sub Nodes as Bones. Deleting individual EZ Morphs sub-nodes from the scene will destroy the integrity of the EZ Morph root Prop and cause iClone to CRASH. Therefore, when adding or deleting EZ Morphs Props from the scene, always ensure you have the EZ Morph root node selected, not sub-nodes.
Have Fun ! :)
Bigboss40@videotron.ca
Universal
