  • Set > Props (208)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Construction Kits for iClone.
This is the ''EZ Roads Construction Kit'' by Bigboss.
This pack include a total of 208 Road Segment Props for iClone. The Road segments consist of 38 different connectable shapes for assembling Roads in just about any type of network. I have provided the Road segments in 4 texture patterns for making Urban Roads and 2 Texture Patterns for making Rural or Secondary roads.
Each segment can be easily snapped together with a Grid setting of ''100'' thus providing with complete seamless connectivity. The Road segments are all at a ''zero'' elevation so that you can easily add an infinite ground plane and physics enabled props.
Best Used in any scene requiring good quality close-up Roads or Streets
Method of Use:
1) Make sure the ''Snap To Grid'' option is set in the iClone preference panel
2) Load and connect desired road segments
3) Multi-Duplicate segments that are used several times to optimize texture map resource usage. (Note that all segments from the same road type use the same base textures so that you can also use the Pick and Paint tool in the Modify material panel to drop the same material on different road segments!)
4) Flip road texture to mach adjacent segment when required
Have Fun ! :)
Bigboss40@videotron.ca
Universal
