Set > Props (176)
accessoire_1 , accessoire_10 , accessoire_11 , accessoire_12 , accessoire_13 , accessoire_14 , accessoire_15 , accessoire_16 , accessoire_17 , accessoire_2 , accessoire_3 , accessoire_4 , accessoire_5 , accessoire_5b , accessoire_6 , accessoire_6b , accessoire_7 , accessoire_8 , accessoire_9 , accessoire_9b , addon_1 , addon_1b , addon_1c , addon_2 , bar , barrel_1 , barrel_2 , baseStone , baseWall_1 , baseWall_2 , baseWall_3 , baseWallConnector , beam_1 , beam_10x0_6 , beam_2 , beam_5x_0_3 , beam_5x0_5 , bench , block1 , block2 , brick_1 , brick_2 , brick_3 , building_1 , building_2 , building_3 , building_4 , building_5 , building_6 , building_7 , building_8 , building_9 , cabinet_1 , cabinet_2 , cabinet_3 , cabinet_4 , cabinetAddOn_1 , cabinetAddOn_2 , ceiling , chair_1 , chair_2 , column_addon , column1 , column2 , column4 , column4_end , column5 , column6 , crate_1 , crate_2 , crate_3 , curb1_a , curb1_b , curb1_c , curb2_a , curb2_b , curb2_c , dirt_1 , dirt_2 , dirt_3 , door_1 , door_2 , door_3 , door_4 , door_5 , doorFrame1 , doorFrame2 , doorFrame2_b , doorFrame3 , doorFrame4 , doorFrame4b , doorFrame5 , floor , ground_1 , ground_2 , ground_3 , ground_4 , hay_1 , hay_2 , hay_3 , hayStack , ladder_2_5 , lantern_1 , lantern_2 , leafes , metalBand , milkChurn , Module_1 , Module_2 , Module_3 , Module_4 , Module_5 , Module_6 , pin1 , pin2 , planks , roof_1_b , roof_1_c , roof_1_end , roof_2_end , roof_3 , roof_4 , roof_4_end , roof_6 , roof_6_end , roof_addon_1 , roof_addon_2 , roof_addon_3 , roof_addon_4 , roof_addon_5 , shutter_1 , shutter_2 , shutter_3 , sideWalk_1 , sideWalk_2 , sign_1 , sign_2 , soil , stall_1 , stall_2 , stick1 , stick2 , stick3 , stone_1 , stone_2 , streetLight , table , torch , tree , tub , tunnel1b , wall1_5x2 , wall1_5x3 , wall1_5x5 , wall2_5x2 , wall2_5x3 , wall2_5x5 , wall3_5x2 , wall3_5x3 , wall3_5x5 , wall4_5x5 , window_1 , window_10 , window_11 , window_12 , window_13 , window_14 , window_15 , window_2 , window_4 , window_4b , window_5 , window_6 , window_7 , window_8 , window_9
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning new Pre Assembled Sets for iClone called ''EZ Sets''.
This is the EZ Set ''Haunted Town'' by TripleBrick studios.
This Pack includes a Modular Haunted Town Level Kit for creating a complete Set plus 6 Pre-Assembled Scene Modules you can use separately or assemble together into a larger scene.
The modular Kit includes:
- 6 Pre-Assembled scene modules
- 9 Buildings
- 12 Ground Pieces
- 13 Pieces of Furniture
- 29 Props & Decals
- 14 Pieces Roof System
- 18 Stones & Columns
- 44 Walls & Windows
- 31 Wood Pieces
For a grand total of 176 Props !
NOTES:
The concept was designed by TripleBrick studios and ported to iClone by Bigboss.
The Assemblies and Props can be used individually or as a group making it extremely easy for you to further customize the Scene.
Haunted Town is the perfect environment for stealth and survival horror Movies.
Method of Use:
1) Load desired Pre-assembled module(s) into your scene (each modules fall right into place)
2) Position Camera.
3) Further customize by adding additional Props to your Scene using the different Items provided in the Pack.
Have Fun ! :)
Bigboss40@videotron.ca
- 9 Buildings
- 12 Ground Pieces
- 29 Props & Decals
- 31 Wood Pieces
NOTES:
Method of Use:
2) Position Camera.
Have Fun ! :)
Rated 0 stars out of 5
1 review
really great! wonderful!
