For iClone only:
  • Set > Props (15)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Animated Tree Props for iClone called ''EZ Trees''.
This is the EZ Trees Temperate COMBO Vol.1 by Bigboss.
This pack includes an amazing set of 15 Deciduous Trees (3 Big Leaf Mahoganies, 3 Black Locus, 3 Common Limes, 3 Dipterocarps and 3 Jungle Trees). The Trees are low polygon count, use high quality texture maps and are fully rigged and optimized for close-up shots and real-time response. Furthermore, each Tree includes 3 embedded animations for simulating wind effect by inducing subtle movements to the trunk, branches and leafs. Furthermore, each Wind Effect animations can be triggered as a performance by right clicking of the Tree and by selecting the ''Breeze'', ''Mild Wind'' or ''Strong Wind'' performances from the pull-down menu options.
Additionally, the Trunk, Leafs and Branches can be further adjusted just the way you want them or animated on the timeline directly from within the iClone Edit Animation Layer; e.g. Adjusting the position of Branches or bending the Trunk for augmenting the wind effect during a heavy storm or for simulating a falling tree.
Best use in Natural Forest Close-Up Shots or Wild Life type of Scene.
NOTES: This Pack requires iClone 5.5
Method of Use:
1) Load EZ Tree
2) Multi-Duplicate
3) Press Play
4) Press Stop
5) Select EZ Tree from Scene Manager Panel
6) Explode EZ Tree sub nodes to see ''Root Node''
7) Select ''Root Node''
8) Right Click in Viewport window to activate Perform Menu
9) Select Mild Wind Performance
10) Press Play
11) Let the Play run the entire sequence to get the complete animation
12) Press Stop
13) Position the cursor to Frame zero on the Timeline
14) Click on the Edit Animation Layer button in the Modify Panel (this invokes the Edit Motion Layer Panel)
15) Select individual Bones, Branches or Leafs Nodes from the Edit Motion Layer Panel
16) Apply desired translation
17) Press Play
Further customize by selecting a different Wind effect performances or by animating individual Trunk Bones on the Timeline !
IMPORTANT NOTES: The different animations are accessible only when the ''Root Node'' sub-node is selected. For background scenes and distance shots, you can delete the pre-loaded animation from the timeline before duplicating to save on processing resources.
Have Fun ! :)
Bigboss40@videotron.ca
Universal
