Set > Props (49)
Fancy Fronts has functional wider front doors with side panels & unique 3d mouldings, and as always, each door has built-in animation for opening/closing the door.
To ensure uniformity and consistency, the fancy exterior & interior wall sets (which have wider front door openings than the standard ones included in the original Master Builder pack) are numbered exactly as their coordinating counterparts in Master Builder & the Garage Kit. So there is no guessing which walls to use when extending your buildings to the east or the west.
Also included are 6 new porticos that are wider balancing the look for a wider front door and each has different textures plus lighting and decoratice plaques.
As with all Master Builder packs, simply make your selection in your content manager & the item will drop into place. There is no aligning required.
Decor items, garage extensions & main building components seen in promotional imagery are from the Outdoor Decor Kit, Garage Kit and Master Builder.
Avatars & vehicles in promotional materials are NOT included with this pack.
The MASTER BUILDER SERIES by Granny J:
iClone > Set > Props > Exterior Prop
iClone > Set > Props > Modern Prop
