For iClone only:
  • Set > Popcorn (2)
"Flow Move ( Leaves & Dummy )" is one of the nature particle effect from the pack : PopcornFX Library 40.
NOTE:
The PopcornFX Library 40 is a set of pre-made PopcornFX particle effects. You can apply these pre-made effects directly to the scene or attach them to props and characters. You may also do limited modifications with the individual control panel.
If you want to tweak existing particle behaviors, import images, sprite textures, 3D meshes and sounds you can sample a static, skinned, or blendshaped mesh for the emitter shape, please acquire the PopcornFX Plug-in for iClone.
Universal
