Material > Material (7)
Set > Props (1)
This is the PBR Flying Eye Pack by SFBStudio.
This Pack contains 1 PBR Morphable Flying Eye Creature for iClone plus 7 high-quality Materials you can use to customize different parts of your character. The Creature is supplied as Morphable Prop with 29 Embedded Animations.
About SFBStudio Creatures:
Each Creature uses high quality PBR texture maps and a very small polygon count providing excellent visual quality for close-up shots.
Method of use:
1) Simply Apply the Prop to your scene
2) Right Click on the Creature to select the appropriate performance
3) Use the iClone "Multi-Duplicate" tool to clone each Creature
4) Use the Morph Animator to further customize your creature
5) Edit the applied animations on the timeline to add randomness to each character move.
6) Another interesting trick is to attach all your Creatures to a dummy Prop and have the prop follow an iPath during the animation!
Have fun!
iClone > Set > Props > Creature Prop
iClone > Set > Props > Sci-Fi Prop
