  • Set > Props (21)
Bigboss is proud to announce the arrival of a series of outstanding and stunning fully animated Props by MaxBugor
This is the FPS Devices Props pack by MaxBugor
This Pack contains 6 x Hand Animated Props for iClone (Same Prop in 6 color scheme) with 76 Embedded Animation plus corresponding standalone Devices to go with the animations (Camera, Listening Device, Phone, Tablet, Walkie Talkie)
Note: This pack is best used jointly with Bigboss's Complementary EZ CAM Controller and EZ Prop Controller Plugin which can be found at the following links :
BB EZ CAM Controller Plugin - iClone/plug-in | Marketplace (reallusion.com)
BB EZ Prop Controller Plugin - iClone/plug-in | Marketplace (reallusion.com)
About MaxBugor Props:
Each Prop uses high quality PBR shader maps and a very small polygon count providing excellent visual quality for close-up shots.
Method of use:
1) Simply Apply the Animated Hands Prop and Device to your scene
2) Attach the Devioe Prop to one of the right or left hands (depends on the device).
3) Select the Hands and Right Click to select the desired performance from pulldown menu
4) Optionally use jointly with Bigboss EZ Prop Controller Plugin to perform walkthrough in your scene.
Universal
PBR
