Check other items in my iClone Content Store
Check other items in my Character Creator Content Store
Another prop which utilizes flexible tubing (after Stethoscope). This one is a bit more complex.
At least a base understanding of Clone Physics is required.
Vacuum Cleaner is fully functional device prop based on Soft Cloth and Rigid Body Physics.
Comes as a project. When saving Vacuum Cleaner parts, you may attach it to some dummy.
But once you brought it to a new project, you need to detach it from a dummy and keep the same props structure as in a demo project.
There will probably be a learning curve to utilize Vacuum Cleaner functions.
Watch the tutorial and be patient while animating cable and a hose.
It takes time to learn about specifics and the right way of doing "things" with Vacuum Cleaner without breaking it.
1/13/2022 - Project is updated. Fixed normals for flex parts.
Universal Project
PBR
