  • Set > Props (253)
Residential Home for iClone 5 & Up
This is the iClone 5 & Up version of the Residential House by NOT Lonely. It is textured with Traditional Textures which include Diffuse, Normal and Spec. This version is only available in the Marketplace.
It's a full Residential Home filled with rooms for the whole Family. Easily walk from one room to another. Doorways and walls match up seamlessly. Use the whole house, or when shooting indoor scenes, load only the rooms required. Each room will function as a stand-alone set, with walls that can be hidden, doors that have a PERFORM, closet and desk drawers that open, window leafs can be raised and lowered. With the 11 included rooms plus garage and Hallways, it's like getting several sets for the price of one.
The entire house can be loaded to the stage with all rooms in position as shown in the VIDEO. Each room is saved separately but when loaded to the stage one by one, it will form the finished house.
Rooms include Living, Dining, Kitchen, Family, Kids, Baby, Office, Laundry, 2 Bathrooms, Main Bedroom plus Garage & Entrance and Upstaris Hall.
NOTE: If using the entire house with rooms all loaded for outdoor shots, I would recommend setting your project preferences to 1024 x 1024. House Exterior without the loaded rooms will work fine at the higher setting. Most Diffuse & Normal textures are 2048 x 2048. Spec is 1024 x 1024.
Animations - Front Door has a PERFORM for Open or Open, Pause, Close. This can be cut on the timeline to adjust the close door for your specific scene. The Garage Doors also have a PERFORM for Open and Open, Pause, Close. All the Room Entrance Doors have a PERFORM for "Open Door".
Closet doors, cupboard doors, drawers - are all set with pivots so that you can animate them to open and close. Rear patio door can be opened/closed on the timeline. All window leafs are subprops that can be lifted and lowered on the timeline.
In addition, rooms have had walls broken down so that you can hide walls for easier filming.
PLUS, you get all the single props to further populate your rooms to look more lived in or for using in other projects.
You can adjust your colour schemes using the HUE dials, the diffuse Box or by launching in your photo program.
Lastly, all the promos for this pack were made in iClone by Alley, including the video, so you can see what you get. More skilled users will be able to really create some high quality scenes.
The PBR version of this set is truly beautiful visually but at the same time, it uses a lot of video/computer resources. Loading the full house or more than a couple of rooms at a time will be challenging for older video cards. This version performs quite well in earlier versions and in iClone 6 & 7.
Universal
