For iClone only:
  • Actor > Accessories (1)
  • Set > Props (1)
  • Animation > iMotion (1)
This is a Futuristic Motorcycle Set inspired by Ferrari's V4 Concept Design. The set contains a futuristic motorcycle iProp, a pose for riding the motorcycle and a motorcycle helmet accessory.
Almost all parts of the motorcycle have their own materials so it is not only possible to re-colorize most parts but it is also possible to remove parts of the motorcycle by setting the corresponding material's opacity to 0. For example, to convert the motorcycle to a electric motorcycle (or one powered by some other futeristic power source), set the opacity for the exhaust material to 0. Similarly for a more futeristic look, the opacity for the spokes material can be set to 0 to create a maglev look.
Contains:
1x Futuristic Motorcycle iProp (with front wheel, rear wheel, shifter, gas tank lid and 2 gauge needle sub-props)
1x Motorcycle Helmet iAccessory (with rotatable visor)
1x Motorcycle Ride Pose
How To Use:
To rotate the wheels use the provided Perform Actions or use iClone's (prop) Rotate function.
To rotate the shifter use iClone's (prop) Rotate function.
To open/close the gas tank lid use iClone's (prop) Rotate function.
To rotate the gauge needles use iClone's bone Rotate function.
To rotate the visor on the helmet use iClone's bone Rotate function.
Disclaimer:
This product is in no way affiliated with Ferrari. Farrari's V4 Concept Design was used as the inspiration for this design but the actual Ferrari concept design looks much cooler. I urge you to google it and see for yourself.
Standard HumanUniversalUniversal
