For iClone only:
  • Head > Face (1)
Bigboss is proud to bring to the market a new type of G5 Heads for iClone called EZ Faces.
This pack contains the Cat Women Cartoon EZ Face.
EZ Faces are High Resolution G5 heads featuring no less than 35 Embedded Morph Targets to handle a wide range of Phonemes and Facial expressions. The Facial expressions Morphs are also mapped to individual 3DX Custom profiles accessible from the iClone Puppeteering Panel so that you can assign them to Facial Expressions that you can control using the Avatar Toolkit Controller Panel.
EZ Faces are fully compatible with the iClone G5 Standard and thereby can be used on any iClone Standard Character.
Furthermore, Easy Faces facial parts are also exchangeable with other G5 Face parts. For instance, you can save the Easy face Mouth Piece and used it on other G5 Heads. When doing so, you may however need to resize it and reposition it to fit the new Character.
Method of Use:
1) Load G5 Character
2) Goto Head TAB and Click Faces
3) Apply EZ Face
4) Click Actor TAB
5) Click on Skin Tab
6) In Material Panel,
Select RL_Upper
7) In Material Settings Panel,
Check "Affect All Materials" Checkbox
Set Diffuse, Ambient and Specular to Full White (This will get rid of the seam line at the neck)
Uncheck "Affect All Materials" Checkbox
Check "2-Sided" Checkbox (This is to avoid seeing through the Neck at angle when the mouth is wide open)
Notes:
- Use Wave recordings for dialog
- Use 3DXCustom profiles 1 to 4 in Puppeteering Panel to add Expressions
I hope you like them !
Have fun!
Bigboss40@videotron.ca
Legacy Actor
