Actor > Legacy Standard Human (1)
This pack contains a G5 Minotaur Creature Avatar including G5 compatible Horse shoes and Minotaur EZ Face.
EZ Faces are High Resolution G5 heads featuring no less than 36 Embedded Morph Targets to handle a wide range of Phonemes and Facial expressions. The Facial expressions Morphs are also mapped to individual 3DX Custom profiles accessible from the iClone Puppeteering Panel so that you can assign them to Facial Expressions that you can control using the Avatar Toolkit Controller Panel.
EZ Faces are fully compatible with the iClone G5 Standard and thereby can be used on any iClone Standard Character.
Furthermore, Easy Faces facial parts are also exchangeable with other G5 Face parts. For instance, you can save the Easy face Mouth Piece and used it on other G5 Heads. When doing so, you may however need to resize it and reposition it to fit the new Character.
This Character is ideal for Mythological and Medieval movie scenes.
Method of Use:
1) Simply load the Minotaur G5 Character and Animate.
Notes:
- Use Wave recordings for dialog
- Use 3DXCustom profiles 1 to 4 in Puppeteering Panel to add Expressions
I hope you like him, Have fun!
Bigboss40@videotron.ca
