  • Animation > iMotion (59)
Bigboss is pleased to announce the arrival of EZ (Easy) Motions for iClone.
I was looking for a way to help users in the creation of quality motion segments in iClone. Using MOVE in iClone to generate default walks typically yield poor results with sliding feet and occasional unrealistic behaviors. Using translational motions provides the vehicle for making perfect walk cycles with good dynamics and no sliding feet!
EZ motions are translational and therefore completely eliminate the "Sliding Feet" issue that often arises with stationary motions.
EZ Motions are perfect motions cycles with starting and ending orientations covering every quadrant of the world axis allowing connecting several motion segments together for providing a seamless continuous action flow. Furthermore, starting and ending orientations as well as segment route are described on the Thumbnail of each motion which facilitates the selection of the next move.
This Pack includes 59 high quality Walk motion segments.
These motions are of generic nature and best used in just about any movie application.
[p class="MsoNormal"]This pack is compatible and fully complementary to all other EZ Motions Pack by Bigboss.
Method of use:
1) Load iClone standard human avatar in Viewport
2) Select any motion segment with starting orientation the same as the avatar
3) Apply motion to the avatar
4) Repeat process for any subsequent motion
IMPORTANT NOTES:
- For optimal performance, when joining cyclic motion segments together, REMOVE the blend section that is automatically added by iClone. Perfect cycles do not require any blend between segments. This is most obvious for Runs, whereby the blend needs to be removed to get a perfect cycle.
- For female characters, when using fast motion segments, it is best to disable spring effect on the breast to avoid breast flattening during motion.
- For optimal performance, please ensure that "Align Actor Motion" and "Reset Motion Root" options are set. These options are visible from the Modify panel of the Motions Tab. These are the default setting.
- For extending motion cycles, apply motion segments to the avatar one after the other. Do not use the "cycling function" from the timeline as it would bypass the "Align Actor Motion" feature and cause the avatar to return to the origin of the motion segment after each cycle.
Have Fun !
Bigboss40@videotron.ca
Standard Human
