For iClone only:
  • Head > Face (2)
Bigboss G5 High Resolution Head Morphs for iClone
Bigboss is proud to bring to market a new generation of High Resolution G5 Faces for iClone, i.e. a series of magnificent higher resolution faces with embedded Morph shapes that can be animated using the iClone Facial Animation Puppet Panel.
This is the G5 Head Morphs "Chewing" Pack for iClone.
These Faces are fully compatible with the iClone G5 Standard. They are fully compatible with ALL iClone Head Features including performing Facial Animation, the capability of using imported CrazyTalk scripts (.CTS files) and the capability of customizing the geometry using the iClone Facial Feature Detail panel or by using 3dXchange 5 and sculpting details in your preferred external 3D Modeling tool.
Notes:
- This pack requires the new version 5.4 or higher of iClone.
Method of Use:
1) Apply head to any standard iClone Avatar
2) Press the Animations TAB
3) Select Facial Animation and press the "Puppet" Button
4) Press the Preview Button in the Puppet Panel and then hit space tab
5) Move you mouse around
Have fun!
Bigboss40@videotron.ca
Legacy Actor
