For iClone only:
  • Set > Props (12)
Bigboss is extremely proud to announce the arrival of a new and original line of products for iClone called "Small Crowds".
This is the Small Crowds Childrens Playground by Bigboss.
Small Crowds are a revolutionary new concept whereby Bigboss has taken Standard Gwynn and Chuck and converted them to Children Props with embedded animations. As animated Props, you can now easily multiply Little Chuck and Little Gwynn in your scene just like you would do for normal Props and benefit from the fact that cloned object instances share common resources thus allowing you to pack more characters in your scene. Furthermore, Bigboss has carefully optimized each mesh to reduce the overall polygon count to less than 15K per character while maintaining maximum quality so that the characters still look good in close-up shots. You can even use the iClone "Multi-Duplicate" tool to clone your characters along a vector or circular path!
Furthermore, each Small Crowd Base Character can be modified by re-texturing or by attaching additional props to its skeleton base (e.g. attaching Hair to the Head Bone of the Prop or attaching prop accessories such as a Bag to the Hand bone). Finally, each applied animations can also be edited on the timeline.
This pack is supplied with 2 Little Boys and 2 Little Girls Small Crowd Bases with a total of 8 Typical Children Playground Animations to choose from including a Skip Rope Loop with corresponding animated Skipping Rope. The pack also includes 8 pre-assembled Small Crowds including Children playing Hopscoth, Skipping Rope, Trying Hand Stands and Running In Circles.
Method of use:
1) Load Small Crowd Base character
2) Multi-Duplicate
3) Position each Character
4) Apply desired performances to each character and adjust on the timeline
5) Press Play
6) Further enhance your scene by re-texturing or attaching different hair style props to the "RL_Bone" of each character.
This pack is a Must have for all Modern Video Scenes !
Have fun!
Bigboss40@videotron.ca
Universal
