  • Set > Props (31)
Bigboss is extremely proud to announce the arrival of a new and original line of products for iClone called "Small Crowds".
This is the Small Crowds MEDIEVAL Witch-hunt by Bigboss.
Small Crowds are a revolutionary new concept whereby Bigboss has converted iClone G5 Characters to Props with embedded animations. As animated Props, you can now easily multiply the characters in your scene just like you would do for normal Props and benefit from the fact that cloned object instances share common resources thus allowing you to pack more characters in your scene. Furthermore, Bigboss has carefully optimized each mesh to reduce the overall polygon count to less than 15K per character while maintaining maximum quality so that the characters still look good in close-up shots. You can even use the iClone "Multi-Duplicate" tool to clone your characters along a vector or circular path!
Each Small Crowd Base Character can be further modified by re-texturing or by attaching additional props to its skeleton base (e.g. attaching Hair to the Head Bone of the Prop or attaching prop accessories such as a Bag to the Hand bone). Finally, each applied animations can also be edited on the timeline.
This pack is supplied with 6 completely different Medieval Character bases (3 Male and 3 Female), 22 high quality animations (13 Male and 9 Female) and 11 Pre-Assembled Small Crowds with different Walk, Sneak Idle and look around Motions. The Clothing layer for these characters was designed by an award winning fashion designer using Marvelous Designer advanced fashion design tools, polygon reduced and rigged to perfection by Bigboss. Furthermore, the materials are presented on separate pre-cut layers making it extremely easy for re-texturing.
Method of use:
1) Load Small Crowd Base character
2) Multi-Duplicate
3) Position each Character
4) Apply desired performances to each character and adjust on the timeline
5) Press Play
6) Further enhance your scene by re-texturing or attaching different hair style props to the "RL_Bone" of each character.
This pack is a Must have for ALL Medieval Fans !
Notes:
- This pack is 2.35 Gb !
- Some low poly Hair meshes used in this pack originate from Arteria3D Characters.
Have fun!
Bigboss40@videotron.ca
Universal
