Set > Props (7)
Bigboss is extremely proud to announce the arrival of a new and original line of products for iClone called "Small Crowds".
This is the Small Crowds Military Action by Bigboss.
Small Crowds are a revolutionary new concept whereby Bigboss has taken Standard Gwynn and Chuck and converted them to Props with embedded animations. As animated Props, you can now easily multiply Chuck and Gwynn in your scene just like you would do for normal Props and benefit from the fact that cloned object instances share common resources thus allowing you to pack more characters in your scene. Furthermore, Bigboss has carefully optimized each mesh to reduce the overall polygon count to less than 15K per character while maintaining maximum quality so that the characters still look good in close-up shots. You can even use the iClone "Multi-Duplicate" tool to clone your characters along a vector or circular path!
Furthermore, each Small Crowd Base Character can be modified by re-texturing or by attaching additionally props to its skeleton base (e.g. attaching Hair to the Head Bone of the Prop or attaching prop accessories such as a Weapon to the Hand bone etc.). Finally, each applied animations can also be edited on the timeline.
This pack is supplied with 3 Soldier Base character each carrying a subset from 9 different embedded military style animations (Crawl, CrawlThrowGrenade, DyingA, DyingB, RunWithWeapon, SecureArea, WalkForwardWithWeapon, WalkLimping, WalkWithCane) to choose from plus 4 pre-assembled Military Crowds (Drill, Bataillon,Crawls and Injured).
Method of use:
1) Load Small Crowd Base character
2) Multi-Duplicate
3) Position each Character
4) Apply desired performances to each character and adjust on the timeline
5) Press Play
6) Further enhance your scene by re-texturing or attaching different hair style props to the "RL_Bone" of each character.
This pack is a Must have for all Concert Fans !
Have fun!
Bigboss40@videotron.ca
Method of use:
2) Multi-Duplicate
5) Press Play
Have fun!
