For iClone only:
  • Actor > Legacy Standard Human (1)
  • Animation > iMotion (9)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Animals by Arteria3D. This is the Gemsbock Antelope by Arteria3D. This Pack contains a Gemsbock Antelope Avatar. The Antelope was ported to iClone by Bigboss. She is presented as non-human .iAvatar that can be fully animated inside iClone. Furthermore, the Antelope comes with her own AML persona and 9 high quality motions; IdleA, Aggressive, Walk, Trot, Run, Attack, GrazeA, GrazeB and Step Back. The Walk, Trot and Run motions are perfect cycles that can be repeated on the timeline. You can also operate the Antelope in iClone Director Mode ! The Jaw and Left and Right Ears of the Animal are skinned to separate bones so that you can also animate them using the iClone Motion Layer Editor. IMPORTANT NOTE: The Motion files for this Animal must reside in the "$iClone Template\Motion\GemsbockAntelope\" folder for the AML to find its way to the motion files Whereby "$iClone Template" environment variable typically translates to: C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 4 Template\iClone Template\ Unfortunately, in REALLUSION City, upon download, the installer will put all motions in the iClone Root Motion folder, i.e. "$iClone Template\Motion\”, thereby, once the installation is complete, you need to create a sub-folder and copy the supplied motions into that folder for the AML to work, i.e create a \GemsbockAntelope\ sub-folder and copy all motions into it. This will then enable you to invoke motions directly from the Avatar Right^Click Pull-Down Menu Have fun! Bigboss40@videotron.ca
Standard Human
