  • Set > Props (10)
Bigboss is extremely proud to announce the arrival of a series of amazing special Props and Accessories by Cricky.
This is the Geo Shapes Particle Drawn Pack by Cricky.
This Pack contains 10 Geo Shapes Particle Drawn signs Props by Cricky with Embedded performances.
A must have for making nice particle animated signs...
Some really simple Props that can Draw or Trace items in your scene, or even on the Chalkboard I created a few months ago.. Use to highlight areas, trace a road, and building or object that you want to draw the viewer's eye to.
Align, Scale, Multi-Duplicate, etc. to create simple shapes or extended tracing or highlighting for complex items. The limit is only where you want the item to be drawn.
Each one comes with a preset perform command that can be placed anywhere you want in the scene and can start at any point in the timeline; just don't forget to adjust the start and end of the particle so it corresponds to the same length as the perform and position on the timeline where it begins and ends. Just a matter of opening both and looking at the Motion and Emit lines respectively.
Method of use:
1) Apply desired Sign Prop to your scene
2) Animate using embedded performances
3) Customize to your liking by adjusting material parameters
Also see Chalkboard with Particle Alphabet :http://city.reallusion.com/ContentPreview.aspx?i=JIC77ee9f012a907fee2&g=
These Props were created by Cricky
Universal
