GhostSheet Character:
Ghost Sheet is an Avatar and uses all the usual iClone motions. These motions mixed with some transforms can give some really great motion effects.
Ghost Sheet is a handy addition for those spooky productions.
Easy To Use:
just apply any iClone motion to the lower body and presto!!! A floating sheet. Transform the character around the screen for better looking sheet flow, and you can have the character follow a path at fast speed for some really goofy results.
Easy To Texture:
Sheet is fully textureable with all the available iClone tools, Diffuse, Bump, Opacity, etc.
You can detach the sheet from the legs to configure your own spring settings, and then reattach to the head when you’re done.
Six ready made iMaterials also come with Sheet Ghost.
Easy To Use:
Easy To Texture:
