Actor > Legacy Standard Human (1)
Animation > iMotion (8)
This is the Giraffe by Arteria3D.
This Pack contains one Giraffe Avatar. The Giraffe was ported to iClone by Bigboss. It is presented as a non-human .iAvatar that can be fully animated inside iClone.
Furthermore, the Giraffe comes with an AML persona and 8 high quality motions; IdleA, IdleB, Aggressive, Attack, GrazeA, GrazeB, Death, Standby and Walk. The motions are perfect cycle that can be repeated on the timeline.
IMPORTANT NOTE: The Motion files for this Animal must reside in the "$iClone Template\Motion\Giraffe\" folder for the AML to find its way to the motion files Whereby "$iClone Template" environment variable typically translates to:
C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 5 Template\iClone Template\
Unfortunately, in REALLUSION City, upon download, the installer will put all motions in the iClone Root Motion folder, i.e. "$iClone Template\Motion\”, thereby, once the installation is complete, you need to create a sub-folder and copy the supplied motions into that folder for the AML to work, i.e create a \Giraffe\ sub-folder and copy all motions into it. This will then enable you to invoke motions directly from the Avatar Right^Click Pull-Down Menu.
Note: This Pack requires iClone 5.3
Have fun!
Bigboss40@videotron.ca
iClone > Actor > Creature > Wild Animal
