  • Animation > iMotion (5)
Go Cart and Driving motions.
1 x Go Cart with 4 performs.Wheels Turn left,Turn Right,Forward and Reverse.Single click operation.
Easy to use -
1. Load Cart-Load Avatar-Don't reposition as when you apply 'Go cart position motion'It will sort itself out.
2.Go cart -Position
3. Now link avatar to cart.
Select the appropriate perform command play then rewind and select the correct motion.
Go Cart Forward- Avatar leans back slightly and appears to drive forward.
Go cart-Reverse-Avatar looks over shoulder while reversing then looks forward.
Go cart Turn Left-Avatar leans looks and steers to the left.
Go cart Turn Right-Avatar leans looks and steers to the right
OVER 500 PROPS & MOTIONS AT THE CRANK'S CREATIONS
Standard HumanUniversal
