Set > Props (2)
This is a set of full and directional shields props. These props where designed to be used with the H-Wing Fighter Exterior prop (sold separately and in the H-Wing Fighter Pack) but they can be re-purposed for custom use.
Contains:
1x Full shield (spherical shield around object with energy texture)
1x Directional shield (partial spherical shield in front of object with energy texture)
The directional shield can be used as both a directional shield (where a full shield is not desired) or to create energy dispersal animations when energy weapons hit the shield. By placing the directional shield at the impact point and starting it off with a 0 size and then increasing its size, the enemy energy bolt will appear to disperse over the shield. A opacity fade out as when the dispersion animation reaches desired full size adds a nice touch.
Disclaimer:
The reference videos uses H-Wing Fighter Exterior, H-Wing Fighter Interior and (this) H-Wing Fighter Shield FX. Each sold separately and in the H-Wing Fighter Pack.
