For Character Creator only:
  • Character > Hair (1)
  • Character > Project (1)
For iClone only:
  • Material > MaterialPlus (7)
  • If you like this, you will love my other hair styles too! Go HERE!  *** Please see import note further down!!!
  • This is also part of a pack! Go HERE and save HUGE!
  • Check out my full store to see High-Quality clothing, shoes, characters, makeup, skin, and accessory’s!!! HERE
  • Conforming
  • Stylish
  • Realistic
  • 4K PBR
  • Easy color change via the color settings or photoshop.
  • Make sure you use the “conform” button after applying the hair to your character.
  • Multiple Color options via Material Plus –See Example photos for colors -  Content located: MaterialPlus>DorothyJean>Realistic Hair V4>
  • Hair is located here: Hair>DorothyJean>Realistic Hair V4>StyleB
  • Bonus project file included to show-case the hair.
  • NOTE: You may get this error message when loading the hair: (1 texture file failed to load) Please ignore this message and press OK. This texture does not impact the look of the hair. This is the Specular mask map and is the same image as the roughness map. You can save out the roughness map and apply it to the Specular mask map slot if you wish. Otherwise, just ignore the error. Again, it will not make a noticeable difference to the look of the hair.
UniversalUniversalUniversalCC Component
PBRExtended
