  • RL Hair > rlHair (1)
HairForLife series 04
Model B (woman and man)
16 morphs to customize the haircut and adapt it to your needs by mixing them.
Possibilities to widen the strands of hair (has the effect of adjusting the thickness of the hair by enlarging or reducing the width of the texture), to turn the strands on their axis, to make them messy and to change some styling elements .
Model composed of 3 parts
_ skull (3 456 triangles)
_ top (10 000 triangles)
_ under (1 144 triangles)
Total triangles: 14 600 triangles
The Front, Top and Rear parts have identical materials, if you export your model, you can merge them or on the contrary keep them in separate materials to have different colors or physical dynamics.
You can choose to use all parts or only some.
For hair color change you have different possibilities.
As the base model comes in a very light blonde, if you want a strong overall color you can simply change the diffuse color in Material Settings.
If you want more subtlety, the Digital_Human_Hair material settings will be wonderful.
The hair of HairForLife serie 04 naturally includes a Root Map which will allow you to apply a color change according to the position in the length of the hair and an ID map which will allow you to have different colors and parameters according to the strands of hair. hair.
CC3+ CharacterCC Component
SmartHairHuman ShaderPBRMorphablePhysicsExtended
