iC7 PBR Dune Buggy consisting of grouped iProps allowing the Dune Buggy to be easily customized at the mesh level (e.g. add lights, move lights, remove lights, etc). Wheels can be animated by rotating the Front and Rear Axle and using Rotate to turn then left or right. Steering wheel can be animated by using the Rotate function. Pedals can be animated using the provided Morph Animations. Individual props use separate texture maps but the texture maps have been combined (see UV settings) to group the texture maps for related content.
