Stage > 3D Scene (1)
This is the ''Industrial Vol.1'' 3D Scene by Bigboss.
iClone 3DScenes are a fast and efficient way to save and restore complete movie Sets in iClone projects including Terrain, Water, Trees, Grass and Atmosphere.
This pack contains a complete ready made scene you can load into your existing project and further customize by adding or repositioning Trees, Grass and Props to perfectly suit the specific needs of your scene. Furthermore, you can also move, scale and rotate the entire scene to perfectly suit your requirements by selecting the ''Landscape'' object via the Scene Manager panel and by applying the desired transformation in the Terrain Modify Panel.
Each 3DScene by Bigboss use a very low polygon count and are further optimized for real-time performance.
Method of use:
1) Load the 3DScene into your project
2) Position the camera to your liking
3) Add your Buildings, Vehicles, Characters and other required Props in your scene.
4) Further customize by changing the Atmosphere, Water, Sky or by adding more Trees or any type of Grass and Moss.
5) Press play !
Bigboss 3D Scenes provide a crisp and clear Environmental Set for all your movie requirements. They are a perfect complement to the amazing series of World Builder Packs distributed by Bigboss by serving as the main Terrain and Backdrop to position your World Builder Props.
Notes:
For optimal performance, ensure your Max Real-time Map Size is set to 4096 x 4096 or more in your iClone's preference panel.
These 3DScenes shine by their beauty.
Have fun!
Bigboss40@videotron.ca
iClone > Stage > 3D Scene > 3D Architecture Scene
iClone > Stage > 3D Scene > 3D Exterior Scene
iClone > Stage > 3D Scene > 3D Modern Scene
