Introducing the Inflatable Morphing Tire. Now you can inflate and deflate your tires as you see fit. Tire includes an air pump subprop with reach targets that can be used to easily animate your characters. Includes one morph for inflating and deflating the Tire. Part of the Inflatables Series (look for the football, soccerball, basketball, tire, earth, pool float). Also included in the Total Inflatables Package. Reach Object Animation Instructions: 1. Click on the PumpBody subprop and detach it from the tire. If it remains a subprop to the tire prop the reach object will not work correctly. 2. Add character to ther scene and position near pump (default position should place pump just in front of character at position 0,0,0). 3. Click edit reach target under the animation menu. Attach the left and right hands to the RumpRReach and PumpLReach dummy subprops (exists under the PumpShaft subprop). Be sure to open the Reach sub menu and activate both the Reach Object and Rotation Modes (See screenshot above) for both hands. Now you can raise and lower the pumpshaft subprop and the character will move with the pump. Easy animating!
