Set > Props (40)
For iClone 5 & Up!
This is a full inside prison scene set up ready to animate. Several of the walls plus the ceiling are separate pieces so you can easily hide for filming. The hallway of Cells consists of 4 furnished cells on on side and another on the right. There is also a furnished interrogation room used for extracting information from the accused. There are 3 entrance doors set up on correct pivots so they can be animated on the timeline. Jail Cell doors are also separate and can be opened/closed on the timeline.
You also get all the single props for adding to the scene or for use in your own projects.
SEE MORE NEW PACKS BY 3D EVERYTHING HERE.
iClone > Set > Props > Modern Prop
