Set > Props (51)
For iClone 5 and Up!!
This is supplied as a complete Kindergarden Play Room with Walls, Ceiling and Floor all set up as subprops. Items against walls are attached for quickly and easily hiding. There is a walled exterior play area as well.
You also get all the single props for adding to the scene or for use in your own projects.
The Entrance Door and the Windows have buiilt in animation with a PERFORM menu for Opening and Closing them. Each window has 3 sections that can be open/close separately using PERFORM.
SEE MORE NEW PACKS BY 3D EVERYTHING HERE.
