Character > Cloth (6)
New version of my labcoat where the coat is formally buttoned up. Also comes with 4 shirt variation parts to go with the coat. The shirts are only the parts that can actually be seen in order to prevent cloth penetration but more importantly to reduce polygon count by not including meshing for parts that cant be seen. All 4 shirt parts fit both male and female and there are 2 versions of the labcoat. 1 for base male and 1 for base female The pants are not included. They are pants that come with character creator by default. I adjusted the characters body opacity map to make the arms transparent so they can't be seen penetrating the sleeves but it was only the arms where I needed to do that. The rest I did with collision shapes. Depending on the animation you apply you will most likely need to adjust your collision shapes and opacity maps to remove penetration.
