Actor > Non-Human/Creature (1)
Animation > iMotion (14)
Set > Props (1)
This is the LACODON Creature by PROTOFACTOR.
This Pack contains an LACODON Creature for iClone plus 14 high-quality Motions. The Creature is supplied both as a Non-Human Avatar and as an iClone Prop with embedded animations.
About PROTOFACTOR Animals & Creatures:
Each PROTOFACTOR Character use high quality texture maps and a very small polygon count providing excellent visual quality for close-up shots. The Prop version of the Character provides additional functionalities such as the capability to use the multi-duplicate iClone feature and the capability to apply key frames to the scaling of bones which may be required by some of the provided custom animations.
Method of use:
1) Simply Apply the Animal Avatar or Prop to your scene
2) Right Click on the Animal to select the appropriate performance
3) You can alternatively Drag&Drop motions on the Avatar version of the Animal
4) Use the iClone "Multi-Duplicate" tool to clone the Prop version of each Creature along a vector or circular path.
5) Edit the applied animations on the timeline to add randomness to each character move.
6) Another interesting trick is to attach all your Character to a dummy Prop and have the prop follow an iPath during the animation !
Have fun!
Bigboss40@videotron.ca
