Project > Project (1)
Set > Props (1)
This is a Light Saber weapon iProp inspired by the Star Wars Universe. Features a detailed base and a resizable blade conpoent so that the prop can be tuned on and off.
Contains:
1x Light Saber Prop
1x Sample Light Saber Project
Note: Due to some issues with scaling on Perform Actions, the prop does not come with Perform Actions to turn the blade on and off but animating this is very easy...just change the Z-Scale of the Blade component (from 2 to about 100).
Effects: if you want the blade to just come out change the Blade component Scale from (X,Y,Z) = 2,2,2 to (X,Y,Z) = 2,2,100. If you would prefer the blade to get thicker as it comes out try changing the Blade component Scale from (X,Y,Z) = 0.2, 0.2, 0.2 to (X,Y,Z) = 2,2,100. This will cause the blade to become thicker as it comes out giving a better effect in my opinion.
iClone > Set > Props > Weapon Prop
