For iClone only:
  • Actor > Accessories (1)
  • Character > Accessory (1)
Lightsaber Basic
iClone Accessory
CC Accessory
NOTES:
Will attach to the right hand.
This is a basic lightsaber design.
Use the Blade Glow Map to change color.
Also changing the strength and the opacity will give you different blade strengths.
There is no on/off function. This will need to be done manually by setting the opacity to 0 to 100
Color ID for the Hilt can be found in the link below if you wish to use iclones substance tools to edit
https://drive.google.com/drive/folders/18OTrEpPRu0u6aCkmxo4JtNmJgm0MiMRw?usp=sharing
Slayerazazel Marketplace
Slayerazazel Content Store
UniversalUniversal
PBR
