Character > Teeth (1)
M3D Base Teeth
- teeth lower root width , lower central incisor root width l , upper central incisor length l , lower lateral incisor edge contour l , upper central incisor move side l , upper lateral incisor edge contour l , upper lateral incisor turn r , lower lateral incisor move side r , lower canine twist l , teeth lower width , upper central incisor twist r , lower third molar length r , lower lateral incisor receed l , upper central incisor width l , upper lateral incisor tilt r , lower lateral incisor edge angle l , lower lateral incisor length l , lower first premolar length r , upper lateral incisor tilt l , upper central incisor edge angle r , teeth upper depth , teeth upper width , lower central incisor root width r , lower central incisor width r , upper canine tilt l , lower lateral incisor twist r , lower canine edge contour l , lower central incisor move front l , lower lateral incisor root width r , upper canine edge contour r , lower central incisor move side r , lower lateral incisor edge contour r , lower canine width l , lowercentral incisor tilt r , lower central incisor edge contour r , lower central incisor receed r , lower lateral incisor turn r , upper lateral incisor root width r , lower central incisor edge contour l , teeth height , lower canine move front l , lower canine edge contour r , upper lateral incisor length l , teeth lower height , lower third molar length l , lower central incisor edge angle r , upper lateral incisor move front l , lower canine move front r , upper lateral incisor move front r , lower central incisor receed l , lower central incisor twist r , upper central incisor width r , lower canine length l , teeth lower scale back width , lower central incisor edge angle l , teeth lower front width 1 , upper central incisor twist l , upper central incisor edge angle l , lower lateral incisor turn l , upper central incisor length r , upper central incisor tilt l , upper canine length l , teeth root width , upper lateral incisor twist l , upper central incisor root width l , upper central incisor receed r , teeth lower length , lower canine length r , lower canine width r , lower first premolar length l , lower lateral incisor width l , lower lateral incisor twist l , teeth lower depth , upper lateral incisor edge angle l , upper canine twist l , teeth upper length , lower lateral incisor width r , upper central incisor move side r , lower central incisor twist l , lower central incisor move front r , lower canine turn r , upper central incisor turn r , upper central incisor root width r , upper lateral incisor twist r , upper canine turn r , upper central incisor edge contour r , upper canine edge contour l , lower lateral incisor edge angle r , upper lateral incisor move side l , lower lateral incisor receed r , upper lateral incisor outer chip l , lower lateral incisor length r , upper central incisor receed l , upper lateral incisor edge contour r , lower central incisor length l , teeth depth , lower central incisor move side l , upper canine twist r , lower canine receed l , lower central incisor width l , lowercentral incisor tilt l , lower central incisor length r , upper central incisor edge contour l , lower lateral incisor move side l , upper canine turn l , lower canine tilt l
M3D Base Teeth
Character Creator > Actor > Body Part > Teeth
